Solving Whirlpool Duet Sport Error Codes Like Professionals.
My display of sport washer is flashing with Whirlpool Duet Sport washer code. My machine has been broken down and I am not able to mend it. Please let me how to get it recovered.
Answered By 100 points N/A #297020
First, disconnect the unit from the power supply. Drain all the water out of the unit. Verify if there is any blockage. Check the condition of the filter. If it is damaged then replace it with a new one. Place back all the components and turn the power supply on. It will work fine if the error persists then call a professional to solve it.
Image result for Whirlpool Duet Sport error codes
Answered By 590495 points N/A #342905
If you have a Whirlpool Duet Sport front-load washer, here are some of the possible error codes you may get and the possible workaround or solution:
  • Error code F01
    • Main control board EEPROM error
    • The problem here is the EEPROM or the Electrically Erasable Programmable Read-Only Memory of the washer located on the main electronic control board which is probably corrupted. For a workaround, unplug the washer for about five (5) minutes then plug it back in. See if the code clears. If this doesn’t help, you need to replace the main electronic control board.
    • Possible parts that need replacement: main electronic control board
  • Error code F11
    • Motor control board failure
    • Unplug the washer and check the wire harness connections between the main electronic control board and the motor control board. Reconnect any loose wires. If the wire harness is damaged, replace it. If the wire connections are fine, replace the motor control board. For more information, see How to replace a motor control board on a front-load washer.
    • Possible parts that need replacement: motor control board
  • Error code F20
    • Not filling
    • Here, make sure the water supply faucets behind the washer are completely open. Check the water fill lines for kinks or freezing in the winter. Check the water inlet valves. If the valves don’t open when activated, replace the water inlet valve assembly.
    • Possible parts that need replacement: water inlet valve assembly
  • Error code F21
    • Will not drain
    • If the washer failed to drain within eight (8) minutes, check the washer drain path for a clog or restriction. Clear the large item filter in the drain pump. If the drain pump doesn’t drain the water when activated, replace it. For more information, see Cleaning the drain pump filter on a front-load washer with no access door video.
    • Possible parts that need replacement: drain pump
For more error codes to check, head down to Whirlpool Duet Sport front-load washer error codes.
