Solving Windows Error Code 80004001
My laptop can not boot and simply says error code 80004001 that I tried a complete reset, but it does not seem more vital than I developed it.
a) When you start the Windows video disc or USB key from your PC, a black screen with the text in gray “Press any key on the CD or DVD” appears. Press any key.
b) Choose the right moment and sort the keyboard.
c) Click Repair Computer in the lower-left corner.
d) In the selection level for the selected note, select the Troubleshooting option.
e) Select Startup Settings> Restart.
g) When your computer restarts, a list of choices appears. Select four or F4 to start your computer in safe mode. Or if you must use the network, select five or F5 for safe mode with the network.
