Solving Wpctrl95 Will Not Run
After installing Adobe Flashplayer, I buy that WPCTRL95 /pivot.ini translation file can not be executed. Should I worry about this and how can I solve this problem of wpctrl will not run?
Log in to the PC as an associated administrator. For a lot of information, see How to Create a Domain or Administrator User Account in Windows 10.
Click Start and sort msconfig. In the search results, select System Configuration.
On the Services tab, in the System Configuration area, select the Hide All Microsoft Services check box,
or select this check box or click Disable All.
On the Home tab of the system configuration, unlock or open the task manager.
On the Home tab of the Task Manager, for each startup item, select it, and then click Disable.
Close the task manager. On the “Start” tab of the system configuration, click “Tap” or “OK” and restart the PC.
After restarting your system, follow the troubleshooting steps to insert, uninstall, or run your application. Your notebook may lose some features briefly in a very clean boot environment. However, this feature may occur if you have configured the PC to start normally after troubleshooting is complete.
