Some details about Nokia N900
I want some technical details about the new Nokia N900.
I want to know which OS is used in it ?
Which all are the supported software platforms ?
Processor and clock speed.
And also its display resolution.
Some Nokia N900 technical details:
1. Touch sensitive wide screen 3.5 inch display.
2.  Pixel resolution is 800×480.
3. Â It supports PowerVR SGX with OpenGL ES 2.0 memory.
4. Â It has Micro-USB connector.
5. Â Bluetooth v2.1.
6. Â Internal storage: 32 GB
7. Â Full QWERTY tactile keyboard
8. Â You can store songs up to 7000MP3.
9. Â It allows 16 GB for additional storage with external microSD card.
10. Camera: five megapixels.
11. On device photo editor is available.
12. It has integrated FM transmitter.
13. Horizontal orientation.
14. JPEG image formats.
     https://www.gsmarena.com/nokia_n900-2917.php
Software platform: Maemo.
Linux based operating system.
The clock speed range is 250 Mhz to 600 Mhz.
http://shootspeak.com/2010/12/05/nokia-n900-performance-tweaks/
1. You can store songs up to 7000MP3.
2. It allows 16 GB for additional storage with external microSD card.
3. It has integrated FM transmitter.
4. It supports PowerVR SGX with OpenGL ES 2.0 memory.
5. Internal storage: 32 GB.
6. Pixel resolution is 800×480.
7. Full QWERTY tactile keyboard.
8. JPEG image formats.
9. Camera: five megapixels.
10.It has Micro-USB connector.
11.Horizontal orientation.
12.Touch sensitive wide screen 3.5 inch display.
13.On device photo editor is available.
14.Bluetooth v2.1.
username- kingahsan50
