Some errors in my iPhone (error code 1015, or 1060)
Hello everyone! I wanted to consult you about the error I get from my Iphone. Whenever I try to update and restore it I kept on getting the error code 1015, or 1060. I had been looking for any solution in everywhere else but no luck. Could this be a hardware problem? I really need your help. Thank you!
Answered By 0 points N/A #151969
I Acquire this has been produced a thousand times earlier but here goes additional one!!!
This is for those of you that are acquiring mistakes while attempting to Restore your iDevice.
Basic Errors include: 3194, 1600, 1015, 1013
Whenever you acquire a 1013 or 1015, you might be nearer to reenabling your iDevice than you think!
exit 'Recovery Mode' as it's called.
For whole additional Errors, follow these commands:
-First, download TinyUmbrella for your electronic computer
-2nd, follow the suitable link below to acquire how to Edit servers File:
–Windowpanes – https://www.ecenica.com/support/answer/edit-hosts-file-mac-windows/
–Mac –
—Easy Method
-3rd, download the microcode you demand from:
http://www.felixbruns.de/iPod/firmware/
***Whenever your downloaded microcode/IPSW is in .zip data format, alter the .zip elongation to .ipsw***
-Preserve your SHSH files
-Go to the boosted tablet
-UNCHECK the Cydia/servers box
-EDIT your servers file cabinet by:
–Taking away the '73.208.105.171 gs.apple.com' chain. (Remember: Vista or Win 7 users need to open the HOSTS file as an Administrator)
-SAVE-SAVE-SAVE the altered data file! BTW, you demand to preserve! 😉
-REBOOT your electronic computer
-Assure the servers file again to affirm it was delivered correctly
-Connect iPhone
-Open TinyUmbrella
-Begin TSS host
-***For customs microcodes merely: Enter PwnDFU Mode with sn0wbreeze or PwnageTool***
-Disclosed iTunes
-Shift (windowpanes) or choice (Mac) and Click reconstruct
-Locate your microcode/IPSW
-Regenerate your phone
-Whenever you get a 1013 or 1015 Error, select 'departure RECOVERY' in TinyUmbrella
You should be bushelled!!!
