I have used WinSCP to display my quotation marks vertically. Recently I noticed that some of the file missing and they are aligned slant. I think I have not made any change in the settings. Have you any idea? How can I solve this problem?
Please help.
Thanks in advance.
Some of the file missing and they are aligned slant
Hi Larson,
This is not a common type of problem. I guess there is some unusual activity happened to you. I would like to advise you to upgrade your security and also the antivirus software. You have to be more careful about the options of the software which may cause damage of the file without your knowing if you do not know how to use the software properly. Try to take help from the help file whenever you feel confuse.
Good luck.
