Some help on How to install new font in x10 xperia
I have some interesting Xperia Themes and fonts on some site but I need help on how to install new font in x1a0 Xperia. Do I need to always reboot my phone in order to apply the fonts?
In order to successfully install a wallpaper, ringtone, theme, or font on your handset you should have first rooted your phone. If you haven't root your phone then do it now. Also try to download Type Fresh and AndExplorer. Install your desired font and save to SD card under /Fonts. Now open the Type Fresh, select MENU BAR then BACKUP FONTS.  Clicks “ALLOW". Select DROIDSANS-BOLD. TTF.
Select the desired font by browsing the font where you saved it earlier. Then "OK". Select DROIDSANS.TTF. Browse the font you used earlier then click "OK". Clicks “APPLY FONTS". About the Rebooting issue, YES the phone should be undergoing a rebooting process every time you change the font in order to enjoy the new font. The rebooting process will take some time so extend your patience to enjoy your new font.Â
