Some help for the PHP Forex open source
Hello experts!
I’m just learning to use PHP. How true that it's easy to develop sites using it? What do you need to implement the PHP Forex open source? Please need some advice on how and if ever anyone knows some scripts. I will really appreciate. Thanks.
Answered By 0 points N/A #162871
Hi Kurt,
I don’t believe that PHP is that much easier as you said. I would prefer JavaScipts than this. Actually it depends on what you are learning for. If you want to work on backend PHP or Perl is good. If you want to work on the browser then you should learn JavaScript. And for learning PHP you should have a strong background in HTML and CSS which will help you a lot and you will find PHP much easier.
