Hi Friends,
Presently I am working on a Microsoft Visio project for our client, for that purpose I need some Visio Cluster Icon. Is it possible to create my own Visio Cluster Icon by using any development tool?
Some high quality Visio Cluster Icon needs to create.
Hi Johnny,
For visio predefined stencils you can go to www.visiocafe.com, you will find almost all the big hardware provider stencils, personally I use the Microsoft stencils (they name it "IT PRO BOOSTER") for my network and server diagrams, it's done in a aesthetical way and you can find almost all you need. However, if you need to create your own stencils, you'll need to create your own images then add them to visio.
Hope this helps,
Janik
Hi Johnny Thompson,
Yes, you can create your own Visio cluster icon. Actually, there are two ways to get the Visio cluster icon, first is by googling the key words "Visio cluster icon" and tap the image search tab on Google. Second is by downloading and using a GIMP software or an Adobe Photoshop program in order for you to create your own image of Visio cluster icon.
