Some links to download that driver for blackberry?
Hello expert, I’m using a blackberry phone. I have to download USB and modem driver for my phone. So, please can you send me some links to download that driver for blackberry?
You can find lots of software that you want for your Blackberry phone. If you want to download some drivers for your blackberry phone like USB modem try this link and also for other software and drivers for your phone, just follow this link.
Hope it helps.
Hello
If you are still looking for a usb and modem driver for your blackberry, I suggest you visit this link.
Another thing is that you need to check the compatibility of your unit first for your desired driver so that it will work without any problems. I hope this help a little.
If you need to install drivers for your BlackBerry Smartphone on your computer, you need to install the BlackBerry software depending on the OS or operating system of your BlackBerry device. The BlackBerry software is in two versions: the BlackBerry Desktop Software and the BlackBerry Link. If you have a BlackBerry Smartphone that runs on BlackBerry 7.1 OS or earlier, you need to download the BlackBerry Desktop Software.
It supports Windows XP, Windows Vista, and Windows 7. Windows 8.x and Windows 10 are not supported. For Mac users, you can download the BlackBerry Desktop Software for Mac. If your BlackBerry Smartphone runs on BlackBerry 10 OS, you need to download the BlackBerry Link. It supports Windows XP Service Pack 3, Windows Vista, Windows 7, and Windows 8.x.
Windows 10 is not supported. It requires Microsoft .NET Framework 3.5 Service Pack 1 so make sure to install it first.
