BRANDONnn
Posted on - 09/22/2011
I have a new window7 that I changed from windows XP.
But suddenly the error pop-ups and I don't know what to do.
I did all the instruction about this, but there's nothing happened it always pop-ups the windows.
Any help me.
MSI Afterburner
Some of MSI Afterburner components are expired, missing or corrupted!
OK
Thanks in advance!
Reddings
It seems that your system was overclocked using MSI Afterburner CFG. Now when you installed a new operating system, its unable to read the MSI Afterburner configuration.
You need to reinstall the application and reconfigure MSI Afterburner profile.
Or
Just uninstall MSI Afterburner. And use your system without Overclocking.
Reddings
The MSI Afterburner message that appeared on your screen is about your video card. I think the post above is right your system might have been overclocked using MSI Afterburner graphics card performance booster.
Try uninstalling MSI Afterburner from your computer and then install it back to fix any corrupted files in the installation and to restore its settings back to default.
After reinstalling the application, configure it for Windows 7 because it was previously configured to run for Windows XP. And the reason why you are getting that message is that you changed your system from Windows XP to Windows 7.
Try downloading the latest version of the software from the developer's website. Remove existing version, and install the new one. Be sure not to download beta's as it might have bugs. After installing, go to the installation folder of MSIAfterburner.
Right-click on the .exe of the software, right-click and select create a shortcut. Cut the shortcut icon and paste on your desktop. When you run the software always use the shortcut you made.
