Some Of My Application Needs Acq.dll Files
When the application in the system needs the acq.dll file, and it is missing from the computer then an acq.dll error occurs in the system. The error message appears on the system ‘This application has failed to start because acq.dll was not found. Re-installing the application may fix this problem.’
The solution to troubleshoot the acq.dll error are as follows:
Solution 1: Re-install the application that requires acq.dll
Solution 2: Update the application to the latest version
Solution 3: Install all the driver and Windows update
Solution 4: Download and install acq.dll
Step 1: Go to the mentioned website.
Step 2: Search for the acq.dll file, and the file will appear of the size 4.2 MB.
Step 3: Download the DLL file and paste it into the system folders of the computer.
Notifications
