Some PDF to word converter work with Windows 8
I usually use converters to maintain scanned documents and convert them to PDF documents and finally to word documents, this way makes it easy to edit and modify them again, a friend advised me to use an easy tool called some PDF to word converter 2.0, when searching for it I found it on websites but it was mentioned that the OS that can work with it starting from win XP through win 7, will there be problems if I download and use it with windows 8?
