Some Problem Is Occurring With Acrobat Distiller, And Acrobat Distiller Is Not Working
The corrupted acrobat file or the stopped Exe program become the reason behind the occurrence of the Acrobat distiller is not working. When the user tries to open the pdf file using acrobat distiller, an error occurs with the description ‘acrobat distiller cannot continue because Acrobat is not activated.’
The solutions to fix the issue are as follows:
Solution 1: Reboot the system
Restart the system and then try to do your task. This is a temporary solution to the problem.
Solution 2: Perform a cleaning task
Step 1: Click on the Start button and go to Control Panel.
Step 2: Choose Uninstall the Program.
Step 3: Look for your problematic application and select it.
Step 4: From the options list, click on the Repair option to perform a cleaning process.
