Anselmo
Posted on - 11/07/2011
Greetings! I need assistance here.
I was having some trouble with SilverLight.
When I was making a canvass and tried to make a few images with it, I just can’t make one.
I tried to place and insert pictures and some images but it doesn’t work.
I even tried using drag and drop application into the canvass to make it faster, but it also doesn’t really work!
I also tried to copy and get some images from the canvass, but it doesn’t work as well.
Could there be any mistake which I might have done?
What easier ways would you suggest to make the program work?
Thanks in advance.
Some trouble working with SilverLight
Microsoft Silverlightis a web application framework which has the same functionality as Adobe Flash.
It has low system requirements for both Mac and Windows operating systems.
If you are using Microsoft Internet Explorer you can install Silverlight directly from the browser.
Mozilla Firefox users need to download the executable file and then run it to be able to install Silverlight.
Windows
Windows XP Service Pack 2, Windows Vista, Windows 7
Intel Pentium 3 450MHz or higher processor
128 MB RAM
Mac
Apple Mac OS X 10.4.8
Mac Intel Core Duo 1.83GHz or higher processor
128 MB RAM
If you are using other applications that have high graphics requirements, you may need to install a sufficient amount of RAM while using Silverlight.
If you are having a problem running Silverlight, you may want to check your computer’s hardware specification if there is a need to upgrade something.
This is a very light application and requires very minimal memory to run.
Disable other applications running in the background while Silverlight is running.
