Hi All
I own Samsung Wave 533/S7230E.
I am trying to download Apps Plugin from Samsung’s website but it returns to previous page, every time I try.
Can someone help me find Samsung apps plugin download
Someone help me find Samsung apps Plugin download
Hello there Barbara,Â
This sounds like you haven't downloaded the PC suite that is catering your phone's requirements before you can download apps. You can download it from Samsung's website, install it and you're good to go. Restart your computer after installing and connect your phone to your computer and access the pc suite. If things still didn't work, you can always try third party applications and I have here a list for you, you can check them on this website. Hope this helps you.Â
Waall Mike
