Donna Davis
20 points
Posted on - 04/04/2013
Fellow Nerds, I have built a fully functional website in HTML, CSS, PHP, jQuery. I wanted to add a functionality where visitors can get a business card editor in PHP jQuery with templates. If it is possible to have this as a separate plugin that I can just incorporate, it will save me a lot of time. Otherwise, a hard coding way is also an option to enable greater flexibility. Thanks.
Someone send me a code for business card editor in PHP jQuery
Hello Donna Devis,
              If you want to do something like that and if you are an expert in html,PHP,CSS and query then you can do this in a very easy way. I am sending you a text file from that one you can get a clear idea that how to do it. It is a complete code all you need is to understand that and you have to implement it in your code in order to get the functionality of business card in your website.
