Something About Offline Mode Outlook 2010 In Short.
Hey, I have been using Microsoft Outlook for 2 years now. It works smoothly online and helps me manage my personal routine. Does offline mode Outlook 2010 work good?
Outlook 2010 is at its acme when used in online mode. But, it takes a long time to load the emails and other data when connected to the internet. So, for using it in offline mode hit the Work Offline button on the tab.
The main advantage of using Outlook in offline mode is that it does not hang up due to the flow of a large amount of data. You can compose emails during the offline mode without any impediments, and those emails won’t be sent to the recipients until it is connected to the net again. So, the main use of Offline Mode is it avoids the productivity lag.
If you are using Microsoft Office Outlook, the offline mode is automatic regardless of its version. The email client shifts to this mode automatically when your computer disconnects from the internet. But when your internet connection goes back online, Microsoft Office Outlook should automatically go back to online mode.
Now, if you want to stay or keep working in offline mode even if your internet connection is working, click “Send/Receive” then select “Work Offline.” To shift between online and offline modes, just check this button. If “Work Offline” is highlighted, it means Microsoft Office Outlook is running in offline mode.
But if this option is not highlighted, it means Microsoft Office Outlook is running in normal mode or online mode. On the other hand, if Microsoft Office Outlook does not go back to online mode, try troubleshooting your connection. Try disconnecting the network cable from the network port at the back of your CPU then plug it back in.
If this doesn’t work, disconnect the other end of the cable from the Wi-Fi router then connect it back. If this doesn’t work, try restarting the Wi-Fi router. If the router has a power button, press it to turn it off then unplug it from the power for about twenty (20) seconds.
Press any button on the router to discharge any leftover power or to power cycle. After this, plug the router back to the power and turn it on. When the router is ready, open your web browser and visit a website then try clicking some links. Verify that your internet connection is working. Once you verify, restart Microsoft Office Outlook then see if it works.
