Hello, Anybody help me of Card Creator Free 11.20.60 software.
Can I install on Windows Xp Operating System? Can I export any photo as .jpg, .gif file format in Card Creator Free 11.20.60? Is there printer setting and free card template available? Is there barcode scanning facility available? Let me know about Magnetic Stripe. Are any additional features are available in this software? Thank You
Something say about Card Creator Free 11.20.60
Yes, you can install Card Creator on Windows Xp operating System. Also you can export any photos in it. The printer setting and card template is available. The software supported by bar-code scanning facility.
Magnetic stripe is a term used in cards means storing the data. In early card technology uses a magnetic stripe which stored the value on it and these value can be read and rewritten every time the card was used. Now a days there are smart cards and optical cards.
Happy to support you!
The Card Creator Free 11.20.60 software facilitates creating versatile ID cards, business cards, etc. It is an ideal choice for small to medium sized organizations who look for affordable card creation solutions.
Yes of course, you can install this on Windows XP since it is compatible with all the recent Windows Operating Systems including XP, Vista, Windows 7 and Windows 8.
Also it supports exporting photos of any extension including jpg, gif, etc.Â
Further this software supports barcode scanning and magnetic stripes can also be embedded into the cards created with this.
It is embedded with multiple free card templates & varying printer settings.
Also this has a simple user interface with great design capabilities, thus suiting all the users from beginners to experts.
