Something wrong with free flip fonts for galaxy pop.
Something wrong with free flip fonts for galaxy pop. When trying to apply the free flip fonts for my galaxy pop it crashes and lagged. And I am afraid that it might harm my phone. What can you suggest about this matter? Would I still apply the flip fonts or just forget about it? I am considering security measurements.
Waiting for your support.
Best Answer by Don Muench
Answered By 0 points N/A #168443
Hi Shawnj,
You can still apply the flip fonts. And you can get  FlipFonts using the Fontomizer app.
You should not be overthinking that there will be something happen when you apply FlipFonts. Some are using non-stock SMS app because of the pop-up notifications.
Hope this works
Steeley Ney
Answered By 0 points N/A #168444
Dear Shawnj Cruz,
Another method is by installing a font package which can fix this problem. It should be compatible with Galaxy.
The compatibility issue should be considered, especially with Galaxy, to avoid any conflicts which may occur after installing the font package.
Try that with care.
Hope that was helpful for you.
With my best regards,
Don Muench
