Davina
Posted on - 10/12/2011
I listen to music from computer many hours per day. Recently I tried to make CD with songs I love and I burned it successfully but the problem that songs sound from CD is not like songs sound from computer. I tried more than CD but still the same problem. So please anyone tell me what is the problem and how to fix.
mactec
Songs sound from CD is not like songs sound from computer
I hope you had already used this Computer and burner to write CDs. It is better if you mention the Operating system you using and what is the software that you use to write the CD. And also what is the type of file you write and what is the method that you use. That means you write data CD or an audio CD.
However there are lots of different file formats that we can write into audio CD
Try this link to get a good understanding about them
Download Link
In your question I there can be errors in two places.
1.      One is your CD burner that you used
2.      Other thing is the player you used to play the songs.
So try some external burner and try to play the CD with different players.
It will give good result.
Thank you….
lee hung
75 points
Hi Davina,
The problem here could be the burner you are using. Some of them burn in poor quality and thus the difference you are feeling for the music on your computer from that on the CD. The burners I myself use and trust are Nero and Ashampoo. They are the best. Or maybe the burner may be fine but the quality you are choosing to burn in maybe poor. I understand when you are writing there are things like normal, medium and high quality that you choose to write in.
Another cause may be your CD ROM drive. It may be having some sort of problems that are affecting the writing process.
Hope this helps.
______
Lee Hung.
