Sonic burn CD/DVD software use in Media Center.
Can all Windows Media Player support.
Like ISO compliant data DCDs (DVD-R, DVD-RW, DVD+R, DVD+RW).
The Sonic burn CD/DVD software and.
How to use Sonic burn CD/DVD software in Windows Media Player?
Hi Manir,
Surely, you can use your windows media player not just to play audio and video files but also to burn and sync your existing files. Windows media player supports a wide range of file types.
Windows Media Player does not DVD-RAM disk burning. Depending on your CD or DVD burner, you can burn CDs or DVDs in the following types: DVD-RW/DVD+RW/DVD-R/DVD+R as well as double layered ones.
Windows Media Player directly uses the DVD/CD writer installed in your PC. To check if you have a working CD/DVD writer or burner follows this flow: Start > Computer > Right clicks your CD driver the choose Properties > Locate Recording Tab/No recording tab means no burner or writer.
Sonic is a separate and a stand-alone software which burns audio and video files independently.
