I have a SonicWALL router at my workplace. And want to in a position vpn access to look at files on the server.
The SonicWALL includes a static public static information science designed.
I have the consumer put in on my laptop, but I will connect.
I am positive i do not have it designed properly on the router.
Can somebody please assist?
SONICWALL TZ205 VPN Access
Assuming the vpn is setup within the SonicWALL properly, here are the directions I send my users (there are screenshots however those do not work here). I even have my users setup through LDAP to active directory however native users work fine too, you only have to be compelled to add them to the wanvpn cluster.
How to setup VPN on a WINDOWS 7/8 machine:
Click begin and sort within the search box Network and Sharing Centre. For WINDOWS eight
machines press the Windows key on your keyboard and search the higher than.
Once found, click to open Network and Sharing Centre.
Once Opened, click came upon a replacement affiliation or network.
Now choose hook up with a geographic point.
Click Next.
