After installing new games to my Sony Ericsson Xperia Play, it suddenly became slow when using it. Sometimes it even hangs. I decided to uninstall the games but it’s still the same. How can I revive its normal functionality?
It seems that the game you installed on your phone was not perfect for your phone. You did well uninstalling that game. If you have any backup for your phone before install that game then run that backup. You can also update your phone software. Update helps to solve previous bugs. You can run factory setting option. Factory setting will make your phone just like a new manufactured device but it will erase all data.
If your Android phone suddenly became slow after installing games and didn’t change even after uninstalling them, try installing Clean Master. The app allows you to optimize your phone by cleaning different kinds of junk files like cache junk, photo junk, system junk, advertisement junk, and video junk. These junk files are actually cache files used by the Android operating system while you are using your Smartphone.
Clean Master
When these junks are cleaned and removed from your phone, it free up RAM which then improves the speed and performance of your phone. The app also has built-in antivirus and AppLock. It also includes a feature called Battery Saver which helps you save battery and extend battery life. This feature analyzes your phone’s battery status and killing background processes to lower down battery consumption.
Another simple way of speeding up your phone is to restart it. This helps if you’ve been using different applications and the phone is starting to get slower.
1....
