Sony External PC Speaker SRS -A3
The sound creates a reflection while volume is little high on Sony External PC Speaker SRS -A3. What is the solution?
Dear Carol Torester you sound is producing a reflection or echo is not the faults of your speaker. The echo produced is often not on the part of speakers it self. The possible reason for it could be misconfiguration in the audio panel. Try to look into the audio panel and check whether your microphone mute is checked or not. Moreover make sure that the pin of the speakers into the sound card is properly plugged in and is not half plugged or improperly inserted. If this doesn’t solves try removing microphone at all and then play sound to check whether it is echoing or not.
