Sony Handycam HDR – CX130 details
Now I am looking to buy a new Sony Handycam HDR-CX130, and I have to clear some doubts on it.
I want to know some of its specifications. I want to know about its – Maximum shutter speed, Image proccessor, Lens type and which type of memory card used in it. Someone please give me this informations.
Answered By 0 points N/A #135449
Sony Handycam HDR-CX130:
– Camera type is Digital HD Video Camera Recorder
– It's maximum shutter speed is 1/10000 sec and it's minimum is 1/8 sec. With this maximum and minimum shutter speeds, you can adjust how your captured photo suggest movement in a still photograph of a moving subject.
– This handycam uses BIONZ Image Processing Engine which was established by Sony.
– It's lens type is G lens, with 30x optical zoom lens, focal distance of f = 2.1 mm – 63 mm and F1.8-3.4 aperture.
– Sony Handycam HDR-CX130 uses Memory Stick PRO DUO and Secure Digital Cards (SD memory card) and having 16GB makes sense because that will let you take around 10,500 3.3 MP.
