Sony Network Error 1106 TV Error Solved
I bought the new Sony Bravia television. It has a feature which lets me play videos on the television directly from the internet. When I try to play any videos from the internet, the television throws the following error sony network error 1106. How do I get around this error?
Answered By 10 points N/A #321281
Sony Bravia is one of the most popular TV brands in the world. Additionally, it is one of the first smart televisions that let you connect to the internet directly from the TV using your Wi-Fi connection. The feature usually works just fine.
The sony network error 1106 occurs when the TV has issues connecting to the internet. This error can be resolved by trying the following. Try and restart your television and reset all your internet settings to default. Then try connecting your TV to the internet. If this doesn’t work, restart your router and try again. If even this doesn’t work, then get your TV checked by the Sony Technicians.
