I have a Handycam windows XPÂ but the sony picture package menu for windows 7 isn't showing and is also not compatible with my adobe flash player. I have tried to upgrade my adobe but still shows no menu. What could be the problem?
Sony picture package menu for windows 7 compatibility
Follow this to solve your problem:
> Open Computer (formerly My Computer), right-click your CD-ROM drive, and select Explore.
> Find the executable SETUP.exe, LAUNCH.exe, or whatever name they use for the installer, right-click it.
> Select Properties, choose the Compatibility tab, and enable compatibility for Windows XP.
> Then double-click the executable to launch the installer.
Hope it helps.
Thanks
Franke Mary
