Sony SmartWatch now available in the US
The Sony smartwatch is a blue tooth device where you can put your information from your smartphones to your wrist.
They are several pros and cons for this device.
The pros is that it has a sleek design ,it can show information at glance,its Facebook and twitter integrate.
The cons however is that you got limited number of applications programs for the smartwatch because of its small size, and it only works with android phones.
Smartphones keep us connected where ever we are, but its kind of pricey with $149 on its belt.
Before you can use your Sony smartwatch you need to download first the Liveware Manager app from Google Play.
Then you can paired your Sony smartwatch on your android phone to receive app and updates.
The Liveware app is used to install app onto the smartwatch itself. You can find this app in some android store together with Facebook and twitter. The only connections offered is through Bluetooth on which you need to paired it to your android phone so that you can use its functions. Without the android phone it will be useless to own this Sony smartwatch.
Sony SmartWatch is a Bluetooth device and is paired with any Android Smartphone using a free application from Google Play. But if you already have a Sony handset or a Sony Smartphone then you should find it already pre-installed. Just check the pre-installed applications in your Sony Smartphone if it is already there. But if not, you can always download the free application from Google Play.
Like any smartwatch, this one from Sony lets you read emails, texts, and social updates. It includes the ability to find your lost phone, even if the phone is set to quiet mode. You can also respond to incoming messages using a preset reply, like for example, “I’m out. Call you later.” It is already available in the U.S. for $150.
