I have a Sony VAIO VPCW216AG, which uses Arcsoft companion 3 software as webcam software.I can record video via my webcam & can also able to video chat on Skype or Yahoo.
But whenever I tried to use my webcam on any website, the webcam didn't detect videos & wont start.
Can anyone help on this?
Thanks in advance.
engrkami
Sony VAIO Webcam Related Problem
You should carefully read the term and condition of the website on which you want to show your live video from SONY VAIO VPCW216AG webcam.
You should take following consideration
1. Are you register in the this site?
2. Is website allow such activity?
3. Is website ask you a code for your webcam and you have not entered?
I hope when all these conditions fulfill your webcam will work.
Thanks
Most of the websites don't allow webcam and that's the reason that you are not able to see your webcam in your website. If you need to use it in a website then check that your webcam supports the format for website.
You can also check the settings for your internet and then can replace them with default settings so that they may be changed for your webcam. Also please check the drivers for your webcam and make sure they are up to date and are working properly.
The last thing i can ask you is that check your webcam on another computer and make sure that problem is in your webcam or in your PC.
