Sony Vegas 11 stopped working through Crashing Error
I am using Sony Vegas 11, and I came up into this crashing error with NV CUDA App & Hardware i wonder if it is with configuration or compatibility.
I am getting the error at the time of rendering the video as even I can upgrade the card but it seems to be block right now and the memory I am using is just half and taking more time in about 46 degrees while the video was rendering for hours and I think the updating of the card bios will set right but I don’t know how to process it and the description of the problem is as follows.
Application Name: Vegas Pro.
Application Version: Version 11.0 (Build 521) 64-bit.
Problem: Unmanaged Exception (0xc0000005).
Fault Module: C:Windowssystem32nvcuda.dll.
Fault Address: 0x000000000694E140.
Fault Offset: 0x000000000027E140.
I hope you can help me with this.
Thank you!
