Sony wireless Play Station 3 key board
I am having problem with my Sony wireless Play Station 3 keyboards.
When I press any key, it takes nearly half a minute to execute the command.
What is the problem?
How will I overcome this problem?
Answered By 0 points N/A #152685
Hi there Ney,
I have read your problem regarding your wireless connection and the lag it has when you try to use the device may be caused by a number of suspects but it is very susceptible to interference try to play closer to your console so that it may receive better signal from you console,
But if the problem still persists you may want to move your console to a better spot like away from your telephone or any other device that gives of wireless signals as this sometimes affects the sending and receiving of your wireless device, you can also try to use this patch its for the UT3 if that is the type you are using in can be found here
