Sony Xperia Mint LT30 Camera
Can anyone tell me the specification of sony xperia Mint LT30. What is the cam quality of that mobile. How much zoom is possible from that mobile.
Sony Xperia Mint LT30p is an exciting upcoming ‘flagship’ dubbed very impressive said to have the iconic Xperia designed Smartphone from sony. The mint code named handset set to have:
1.      A Snapdragon S4 processor (the cores are not defined yet)
2.      A  4.6-inch HD display with resolution of 720 x 1280,
3.      1 GB of RAM
4.      16 GB internal storage
5.      Expandable by microSD form IT68.
6.      13 –megapixel rear camera accomplished with Exmor R sensor and 1080p video capture.
7.      Another surfaced viewable camera will be available with the Xperia Mint
8.      NFC support with screen buttons.
9.      Android 4.0 ICS upgradable to 4.1 Jelly Bean.
If you are referring to Sony Xperia T or known also as Sony LT30p then here are its specifications. The Sony Xperia T is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled to the public on August 2012 and released on September 2012 measuring 129.4 x 67.3 x 9.4 millimeters and weighing 139 grams.
It uses micro-SIM card and has TFT capacitive touchscreen display with 16M colors at 720 x 1280 pixels screen resolution. It supports multi-touch up to four fingers protected with shatter proof glass. It runs on Android 4.0.4 Ice Cream Sandwich upgradable to Android 4.3 Jelly Bean powered by Qualcomm MSM8260A Snapdragon S4 Plus chipset, 1.5 GHz Dual-Core Krait processor, and Adreno 225 GPU.
It supports microSD expandable up to 32 GB. It runs on 1 GB RAM with 16 GB internal storage. The primary camera supports 13 megapixels with AF featuring LED flash and supports 1080p video recording at 30 fps. The secondary camera supports 1.3 megapixels and 720p video recording at 30 fps.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 3.1 with A2DP support; GPS with A-GPS and GLONASS support; NFC; stereo FM radio with RDS support; and microUSB 2.0 with MHL TV-out and USB Host support. It has built-in accelerometer, gyro, proximity, and compass sensors. The pre-installed web browser supports HTML5.
It runs on non-removable Li-Ion 1850 mAh battery with standby time up to 450 hours on 2G and 410 hours on 3G. Talk time is up to 7 hours both on 2G and 3G. It is available in black, white, and silver colors.
