Posted on - 06/19/2012
Sony is now going to be launches its another new Android Smart phone .
This is the first Sony mobile which works on Android Ice Sandwich Version.
Any one know its approximate price in India ?
Does the phone have gorilla glass on screen ?
Sony Xperia Neo L launches
Sony recently announced that their mid-range phone, the Sony Xperia Neo L, is going to be globally available. This is good news because last March Sony announced that this smart phone was only going to be released in China. However, there is no news yet of the official release date in India. Pricing of the unit is actually unannounced too, but don’t expect its price to compete with current smartphone monsters iPhone and Galaxy S3. Price of the Sony Xperia Neo L is not that expensive because it will still use some of the technologies that are already a year old.
Regarding the question if the Sony Xperia Neo L is outfitted with Gorilla glass, well you’re in for a problem. This particular Sony product does not sport the protective Gorilla glass that are shielding most of the high-end smartphones today.
Maybe Sony deliberately did this to bring the cost further down. So if you’re going to buy the Sony Xperia Neo L, make sure to always keep it in a safe place because its screen is just the usual standard.
I am excited about the Xperia Neo L too! I am looking forward to buying them.Â
Too bad it doesn’t have gorilla glass screen, but Anyways I am going for it.
Thanks to the expert for his advice,
Thank u very much
There are several ways of keeping your laptop temperature low when using it. One way is to minimize number of active programs, running several programs at simultaneously is taxing on the processor and RAM chips. This leads to more power consumption and heat output. Altering screen brightness, lowering the quality of graphics especially for video games and keeping it away from direct sunlight can help reduce operation temperature. You should also avoid using battery power whenever possible, internal batteries generate heat whenever power in drawn from them.
Regular maintenance of your laptop is also very important. You should blow your laptop regularly to remove dust which accumulates inside the cooling system and on motherboard chips. This can be usually accomplished by using canned compressed air. An alternative is to use a handheld vacuum cleaner. This should be done only when the laptop has been turned off and been discharged.
You can also employ external fans to blow air across the laptop to help ventilate it. The laptop should be probed up from the table or desk, and then fans can be set up so that air currents flow beneath the laptop, blowing hot air away.
However in order to achieve better cooling, one can purchase commercially available coolers from nearby retailers. A typical cooler consists of a chassis fitted with one or several fans. The chassis helps to elevate the laptop while fans create air flow. Cooling pads like the one shown below are one of the best ways of keeping the laptop cool.
Figure 1Typical laptop cooling Pad
There are various types of cooling pads. The best are Targus Chillmat and Spire Pacific Breeze. Other method of cooling laptops includes the use of Arctic silver gel; a thermal compound made of silver.
Thanks for posting your question here. I am also excited for the new android smartphone that Sony will launch in the market. It is Xperia ion. It is the first Sony LTE smartphone and it has nice specifications.
Look at the picture below.
That is the back view and front view of Xperia ion and the only available color is black. Its features are the following:
1. 5.1 ounces and it weights 144 grams
2. its size is
5.2 x 2.7 x 0.4 inches
133.0 x 68.0 x 10.6 mm
3. Talk time is up to 10 hours, standby time 400 hours and music listening is 12 hours
4. It is a Google android (gingerbread) and 1.5 gHz Qualcomm dual core processor
5. Its camera megapixel is a2.1 focus and 16x digital zoom with LED flash
Its expected price in India is Rs.30000.
I hope these information's will help you.
