I have a Sony Xperia T3. My phone got pretty slow lately and last night it went black. The notification light was blinking but the display won't turn on no matter what I did. I kept on trying for two hours but to no good. I tried connecting it to my laptop as well but nothing happened. Is my phone dead for good? Or is it a problem with my display? If not, what can I do to recover my phone? Are there any soft wares available to recover the phone from such a state?
Sony Xperia T3 went black and won’t turn on.
It is not confirmed but I can confirm you that it is a hardware problem or software problem follow the procedure for this.
Turn your mobile off and take off the battery and put back again.
Press volume down, home button and power button until mobile vibrates.
Select the Wipe All The Data by using the volume buttons.
After that select All by using the power button mobile will be formatted.
After that select the reboot.
If the phone turn on normal, then it is ok otherwise it will be hardware problem then visit the Sony store in your area.
