Sony Xperial go mobile details
Does anyone have information about the Xperia go which is water proof, dust proof. Is it good to buy that mobile or need to wait for some more time to look at other mobiles of the same kind.
Sony has launched its new mobile which is 'Sony Xperia go' which is dust proof, water proof. The features of this mobile are it comes with 1 GHz dual core processor, 5 MP camera and 3.5 inch display. The OS they are providing is Android 2.3 but you will get an option to upgrade it to ICS 4.0. It is good to buy this mobile.
If you want to go only for Sony Ericsson mobile then you can wait for some more time so that the price will come down and you can expect a few more releases of the same kind from them. But, If you want to buy any water proof, dust proof mobiles then check Motorola defy, even it provides the same features with less cost at present.
I have attached the mobile picture of Sony Erickson go mobile it comes in three colors black, yellow and white.
Sony Xperia Go is a dust-proof, water-resistant phone up to 1 meter for 30 minutes and is best if you love outdoors. Because it has the highest resistant display that can handle the bumps. This Android Smartphone has a RAZOR sharp 3.5" Reality display with Mobile BRAVIA engine that is best for watching your favorite shows.
You can download, browse, and steam anything on this dual core 1 GHz Cortex A9 processor phone. The internal memory is 8 GB and you can also use a Micro SD expandable to 32 GB more. It is also best for taking pictures with its 5 MP rear-facing camera with auto focus and LED flash. It comes with Android Gingerbread version 2.3 but can be upgraded to version 4.0 after its release.
The Sony Xperia go is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled on May 2012 and released on July 2012 measuring 111 x 60.3 x 9.8 millimeters and weighing 110 grams. It uses mini-SIM card and has LED-backlit LCD capacitive touchscreen display with 16M colors at 320 x 480 pixels screen resolution.
It supports multi-touch up to four fingers protected by scratch-resistant glass with IP67 certification (dust proof and water proof up to one meter for 30 minutes). It runs on Android 2.3 Gingerbread upgradable to Android 4.1.2 Jelly Bean powered by NovaThor U8500 chipset, 1 GHz Dual-Core Cortex-A9 processor, and Mali-400 GPU. It supports microSD expandable up to 32 GB.
The Sony Xperia go Smartphone runs on 512 MB RAM with 8 GB internal storage. The primary camera supports 5 megapixels with LED flash and autofocus featuring geo-tagging, touch focus, face and smile detection, and panorama. It can record video in 720p at 30 fps. It doesn’t have a secondary camera.
It has 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with DLNA and hotspot support, Bluetooth 3.0 with A2DP and EDR support, GPS with A-GPS support, stereo FM radio with RDS support, and microUSB 2.0 with USB Host support. It has built-in accelerometer, proximity, and compass sensors. The pre-installed web browser supports HTML5 with Adobe Flash support. Java is supported via Java MIDP emulator.
It runs on non-removable Li-Ion 1305 mAh battery with standby time up to 520 hours on 2G and 460 hours on 3G. Talk time is up to 6 hours 30 minutes on 2G and 5 hours 30 minutes on 3G. It is available in black, white, and yellow colors.
