An error message occurred when trying to upload a csv file to the S&OP HANA Cloud database. Have anyone experienced this error message? I want resolution to fix this annoying error message ASAP. I would be grateful to you.
S&OP: Error
An unexpected error occurred. Try again later. If the problem persists, report the error ID 1a5bf2d2-e318-11e2-9e9a-123139367f55 to your system administrator.
S&OP error when uploading a csv file
S&OP error usually occurs while uploading a CSV file. There may be many reasons behind this error. If you face this kind of problem then you should inform your system administrator as soon as possible. You should also request your system administrator to check the master data of the S&OP HANA Cloud database. If the system administrator ensures that there is no duplicate data into their database then hopefully you would be able to resolve your problem.
