s1nayder
Posted on - 12/28/2011
When I tried to convert workbook from excel, multiple dialogue box appears and this error message “Sorry, the activation code given cannot register this version of the software”
Why this is? And how it can be fixed?
Hello friend
The registration fails before upgrading to the latest version. You are required to install the latest version. You don't need to uninstall it, you just need to upgrade to the most recent version. You can get the software from Microsoft with available internet connection. Do not use any illegal software as it always contains Trojans and viruses. You can also try to uninstall your software completely and then download the most recent version and install it to your computer.
Hello S1nayder,
If you are receiving this message, you are most probably trying to activate a version of this software completely different from the one that you purchased.
To fix this issue, please visit this site: https://www.docudesk.com
Search, download and install the latest version of the software that matches the product you purchased.
This should help you surely.
