Lee F Parks
Posted on - 08/14/2014
Hi there,
This is the error that I have with Windows Vista when I am trying to install Nokia Suite for my phone. I have the latest version of my driver and the installer is compatible with Windows Vista. Any solution for this error ? How can I install Nokia Suite properly ?
Thank you !
Vista support will be added again as soon as possible. Visit https://www.nokia.com/phones/en_us/support for more information.
points
Sorry Microsoft Windows Vista is currently not supported
Sounds like you’ve been trying to install a very old version of Nokia Suite. The latest installer supports Windows Vista and you should try it.
Download the latest Nokia Suite. The version is compatible with your Windows Vista. Just download and install. Make sure that during the installation, internet connection doesn’t get interrupted.
For better performance, you should upgrade your Windows Vista to SP2. According to your Windows version, download 32-bit or 64-bit SP2 update for Windows Vista.
Now, try to install Nokia Suite. Hope it should go fine.
