Sound card problem! help please
Hello guys,
I need help on my soundcard here it is a ac 93 cmedia and I cant find a driver for it by the way iam running on windows 7 and I have tried driver robot but no luck at all. What can i do about this?
Hello guys,
As of now there’s no driver for cmedia ac93 for windows7 operating system. The only option is to change your soundcard that can be use for windows7 and install the new driver for it.
I tried finding the C-Media AC93 driver for Windows 7, but I'm not sure if there is a product exactly like the one you were looking for. C-Media has the AC97 but not the AC93. If you need further help, you can go directly to their webpage. Just click on the link below:
https://www.cmedia.com.tw/EN/index.html
If you were looking for an AC97 driver, there is no driver available for Windows 7. You can play it on your settings, and I am sure that it will work fine with Windows 7.
If you have a problem with your sound card or you want to reinstall it, the easiest way to get the driver if you don’t have it on your computer is to download it from your computer manufacturer’s website. Like for example, if you have a Lenovo desktop computer, just visit the Lenovo website and go to the support page to get the driver.
This will allow you to get the complete set of drivers for your machine without having to manually search them one by one on the internet. On the other hand, if you need to download the driver for the CMI8738 sound card, download from here:
