Sound of my computer not working
Dear All,
The sound of my computer is doing funny thing.
When I watch movie it works fine. But when I play audio song the sound does not work. How can I fix it? Thanks
Dear All,
Hello it looks like your volume mixer on Windows is muting the program you listen to your music to.
Firstly let me show you the volume mixer on Windows 7, the one in red is the mixer, left click on that icon and click on the text Mixer.
Then you will see a window such as this, keep playing your music by this time and check if the mute button is pressed, like I pressed mute on the Winamp Application, if you observe the other applications VLC Media Player and Windows Media player are not muted and both of them are most popular applications for playing Videos.
Once you click on the mute button of your music playing program, you should be doing fine.
If it doesn’t work, try and install your music player.
Make sure the digital cable are in place digital cable are the cables that goes from the CD/DVD drive to the sound card or to the motherboard.
Make sure is placed well and you problem will be solved
