Sound quality of midi to wav 2011 converted files
I want to convert some midi files to wav 2011. I have found some freeware in the internet to do so. But I am confused about the sound quality. Will the sound quality become poorer? Can anybody give me some names of freeware which won't hamper the sound quality.
Answered By 5 points N/A #153639
You can change with iTunes midi to wav format. Download iTunes import with dragging the midi file into iTunes, set the settings in menu bar > edit > preferences > general > import settings > import using and choose WAV Encoder.
Then select the file that you want to convert and by selecting advanced in a menu choose Convert Selection to WAV.
I don’t think that you will loss sound quality.
There is also this link to download MIDIto WAV Converter:
Here you can find tutorial how to download, install and use the program.
Williamson Mellisa
