Sound quality is too bad in Nokia Asha 200
Nokia Asha 200 has its own features and limitations and It did fairly well compared to other brands within the same range of price. When it comes to its limitations which goes along with its reasonable price I think it was fairly good for everyone. Even the music player was simply superb for this price range although it has no dedicated volume key. Anyway, the materials used by Nokia was of good quality. Nothing we can do on how to improve the sound quality because as I had said it has its own limitations. So, it depends on your needs now. I advise that you rather choose other units or even other brands with a quality audio featured along with the phone but of course the price range varies.
I think your problem with the sound is when you are playing music with your Nokia Asha 200 Smartphone and not with the sound you are hearing when doing a phone call or a voice call because this is different. Just like with my sisters Samsung Champ, the sound is great when playing music with the handset but during a voice call she says the voice she hears from the person on the other end sounds muffled and hard to understand.
After learning about this I tried to contact Samsung from their official website regarding the problem but I didn’t receive any reply from them. If your problem is somewhat similar, I’m not sure if you can find a solution to it since its manufacturer rarely replies to any complaints and inquiry. But if your problem is with the sound you are hearing when playing music, you can improve its quality by installing the “AnEq Equalizer 1.0” application. It is a 5-band graphical equalizer available at Mobyware | AnEq Equalizer 1.0.
Here is the QR code for AnEq Equalizer 1.0. Just scan it with your Smartphone to download.
If you don’t have a bar code reader on your phone, you can download one from Mobyware | Barcode Scanner.
