Sound recorder driver windows 7 not installed properly.
I have windows 7 installed and recently updated my sound drivers. Since then whenever I try to record something I receive error saying sound recorder driver windows 7 not installed properly. I was wondering if someone knows the cause of this problem and how to rectify this issue? Any kind of help would be appreciated.
Answered By 0 points N/A #134013
There are some methods to fix the problem. The method given below is the easiest and simple – I think. So…..
Go to Start and then Control Panel
Click in Sound
When you see a new window, click on the tab Recording
Right-click in the window and click on 'Show disabled devices'
Can you find the Microphone here?
I think you find.
Now Right-click and choose Enable
Last of all Right-click on it and update the driver under Properties option.
Thanks for asking.
Hathy
