Sounds from Video Still Heard Even After Closing Mozilla Browser
My current OS version is Window 7.  Whenever I view a video and after a while close the browser, I can still hear the sounds.  Why does this happen?  Is something wrong with Mozilla Firefox? I always use Mozilla Firefox when browsing.
Answered By 0 points N/A #105003
It’s a common problem with Mozilla, because some time it doesn’t stop streaming even if you closed it. But you can fix the problem by reinstalling it. But first you have to remove it completely then Install. Don’t forget to restart your computer after removing the software. if you are using other than version 3.6 then you should download this version, Because this version is more user friendly then others. And it would not do anything without your permission. On other hand you can change from Mozilla to chrome. Chrome is the latest invention of Google. And it is much faster than Mozilla. Most important thing is you can keep it totally add ones free if you want or you can add any add one which you are using in Mozilla. MY suggestion is Now it’s time for change.
