Soundtrack Error Message: MacPro related
        I have Final Cut Pro X in my Mac PC.
I am trying to send a sequence to it to my Soundtrack Pro that will be used to mix some audios.
But I got an error on doing it.
An Unexpected Problem
NSInternallnconsistencyException
Invalid Parameter not satisfying: m_mainWindows
OK
To resolve my problem, I opened the file in Soundtrack Pro but did not resolve it. I changed some settings to no avail.
But when I tried to open the project in other computer system, it works just fine. So I’m guessing that the problem is in my computer system. I did everything such as update, uninstall and re-install Soundtrack Pro but I could not resolve the issue.
I am running Mac with OS X Lion.
How can I fix this?
