Soundtrack Error message: registration error
I have an Apple Soundtrack Pro that is giving me a headache for the past few days.
I keep getting a Registration Error when running it.
This software is a registered version, and I got it from Final Cut studio.
How can this happen?
And also, I have been using it for quite some time now without errors.
Please send some help.
Thank you.
Registration Error
An error occurred: coreFoundationUnknownErr.
Answered By 5 points N/A #109894
Have you been getting that problem ever since you installed the SoundTrackPro application or the error just started occurring recently? From the error message it seems like the problem is with the registration of the application. You may have used wrong registration details like serial numbers or activation keys and that is why you are getting that error. The problem may also be as a result of an issue with the registry entries for that application. They may be corrupt, or they may be missing. You will need to check the setup if it had a file for registry entries that you were required to run and then run it, or you can just reinstall the application to fix any bugs that might have developed in the application.
-Experttechyv
