Jamin Ywain
60 points
Posted on - 09/28/2012
I am having a problem with my Soundtrack pro. I will no longer work after I upgraded to Logic Studio 9. I was using Logic Express 9 before, but after I upgraded to Logic Studio 9, soundtrack pro no longer works.
Please see below error message after opening it in Logic Express 9:
Dyld Error Message:
Library not loaded: /Library/Application Support/ProApps/*/ProFX.framework/Versions/A/ProFX
Referenced from: /Applications/Soundtrack Pro.app/Contents/MacOS/Soundtrack Pro
Reason: image not found
Before I go to the Apple Store to seek help, maybe I can find help here as my last resort.
Thank you for your help.
Soundtrack pro no open after upgrading
Try reinstalling your application. Your previous upgrade was not completed or something have occurred while upgrading, The error says that some of the programs libraries was not loaded and that is the cause of the error. I think that one of the images of the program was not loaded so that why it is not working.
First delete the Soundtrack Pro preferences manually. Then go to -/Library/Preferences/ and delete com.apple.soundtrackpro.plistEmpty the trash. And now just for good measure, shut down (not a restart) the Mac, wait the count of 10 seconds, and then start the Mac again. Now try launching STP. Your issue should be solved.
WITH REGARDS
WELCH SANGER
