Emma Marie
10 points
Posted on - 03/20/2013
Hello Techyv Friends,
I am new to ASP.NET and would like to have the source code of ASPNET room scheduler using dhtmlxScheduler for me to understand about integrating the dhtmlxScheduler into an ASP.NET, Please do the needful for finding me the source code along with tutorials for that.
Thanks in Advance,
Emma Marie
Source code of ASPNET room scheduler using dhtmlxScheduler
Hi Emma,
Here are some links that could be useful to you in learning ASP .Net and integrating dhtmlxScheduler to ASP.Net.
How to build room booking system
Event Calendar for ASP.NET MVC with dhtmlxScheduler
These two articles are similar to the you are looking for. Here’s another link which is full of dhtmlx Scheduler examples and source codes.
Some of it is in java but you can still integrate it with ASP.Net.Â
Hello Emma Marie,
As this is a good technique that you are doing with (asp.net). I am giving you a source code which surly can help you in getting the point and can also help you in other connection using asp and using DHTMLxScheduler.
Here is a complete code of room schedule with the integration of DHTMLxScheduler.
The screenshot is also given below for the software.Â
There is a file attached to this post you can get the code from there. It is a easy code not a tough one to use and understand.
Hi Emma,
Dhthmlxscheduler is a web-based event calendar which provides simple in browser scheduling solution.
It is a pure javascript solution that can be easily connected to the backend database with the help of dhtmlxconnector or using your own server side written in any language such as PHP, Java. ASP to bind scheduler content to the database.
If you want a tutorial about how all of these are being integrated then a tutorial is being provided online Visit
