Source file not found when installing IBM SPSS Statistics.
Asked By 100 points N/A Posted on -
Hi fellows
Yesterday I was trying to install the IBM SPSS software for windows from a DVD but I get an error during the installation. The screenshot of the error is attached below:
Error 1311.Source file not found: G:Mule CompleteIbm Spss Statistics 20 (x32-x64) & Amos Multilingual-EquinoxIBM.SPSS.Statistics.v20. x64...Common.cab
The error states:
Error 1311.Source file not found: G:Mule CompleteIbm Spss Statistics 20 (x32-x64) & Amos Multilingual-EquinoxIBM.SPSS.Statistics.v20. x64…Common.cab. Verify that the file exists and that you can access it.
If anyone has any idea what does this error code 1311 means, please guide me. How can I remove this error message to make a successful installation.
Waiting for your suggestions
Regards
Best Answer by Cagara aehlam
Answered By 0 points N/A #190665
Hello Martin,
Error 1311 means that you don't have permission to install a program from the CD or DVD. To solve this problem follow the following steps:
1. Create a new folder for example "ibm".
2. Insert the software setup CD or DVD into your optical drive.
3. Go to my computer. In the My Computer window, double-click on the CD drive to open it.
4. Select all the components of CD or DVD , copy them and paste into the folder "ibm".(created earlier).
5. From among the files you just copied, double-click on "Setup.exe." .
6. Setup will start and software will install.
I hope this will solve your problem.
Answered By 0 points N/A #190666
Hi There,
Installing IBM SPSS software requires that installer must be run as administrator. Having it installed from a physical media (DVD/CD) and encounter Error 1311, the following may help you run the installer.
Create a Folder in your local hard drive (with name IBM for instance).
Locate from your DVD/CD drive the directory of IBM SPSS usually found under file name WindowsSPSSStatisticswin32 (or) WindowsSPSSStatisticswin64.
Copy the file from the DVD/CD found in this directory and paste it into the previously created folder in your local hardware (named IB).
Open the new folder (named IBM) where files from DVD/CD were copied. Find a “setup.exe” file. If found (ideally, it should be there), double click to run the installer or right click the file and select Run as Administrator, if Windows 7/Vista.
Follow on-screen instructions and installations must now be complete to finish the set-up.
Hoping that this option could help.
